Konica Bizhub C3350 Scanner lock
  • copierjeffstl
    • Oct 2017
    • 18
    Has anyone come across this before?
    Scanner lock message comes on in the middle of scanning through doc feeder.
    Of course the scanner lock is in the off position.
  • copier tech
    • 8142
    Re: Konica Bizhub C3350 Scanner lock
    Usually the drive belt snaps causing this message.
    • copierjeffstl
      • Oct 2017
      • 18
      They said they looked at belt and it's not broken.
      What about it being stretched?
        • 23006
        That scanner comes as an assembly (A3GN 2601 00) ... no sub assembly parts. And if it is a Lexmark build ... yes, Lexmarks are known for snapping that length of timing belt, then displaying "SCANNER LOCK" condition. Maybe you can see the condition of that timing belt through the glass?
        Disassembly of the scanner will only be to resolve your curiosity, since there are no individual parts available. =^..^=
        • copierjeffstl
          • Oct 2017
          • 18
          I already checked on the belt, it is available as separate part.
          • copier tech
            • 8142
            Yes KM have released a few parts in the optical unit due to demand from service.
            C3350 Scanner Lock Error.pdfC3350 Scanner Lock error 2.pdf
            • copierjeffstl
              • Oct 2017
              • 18
              Copier tech
              thank You very much for tech bulletin.
