Code - 2152
  • David Beck
    • Mar 2025
    • 21
    Code - 2152
    Hi everyone, I have a C458 with code 2152, apparently the customer tampered with the transfer belt and gave this code. I've already replaced the entire set, I've already checked the location sensors but the engine doesn't turn or start. Do you know what it could be?
  • Synthohol
    Certified Konica Expert
    • 5839
    what does ps39 show blocked and unblocked?
      • 23008
      Often the retraction sensor gets blown over with a dusting of toner, and does not correctly read the position.
      • aberock
        • May 2022
        • 124
        give a good blow at the itb area
        • David Beck
          • Mar 2025
          • 21
          the sensor was bent guys hahahah I don't know how but it worked
