C250i Coloured Backgrounding
  • barber782
    • Aug 2011
    • 277
    Hi folks,
    Iv attached a print sample of an issues we have with a C250i. The technician has changed the drums, transfer belt and roller already.
    any help you be greatly appreciated.
  • AKUGLOBA
    • Mar 2025
    • 2
    Change the high voltage, if it persist change the IDC sensor.
    • tsbservice
      Field tech
      • 7909
      Looks like PH unit.
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5735
        anyone try the background data reset and stabilize?
        rescued a few machines with overcast like that and the reset worked 8/10 times.
        yours looks pretty intense though.
        • Max
          • Oct 2011
          • 545
          Was the drum original? Brand new? If that was a second hand drum, without the reset chip then this would be the result.
          • kingarthur
            • 1301
            Or an old drum that has been newly chipped
            • barber782
              • Aug 2011
              • 277
              I've asked the technician to take out the HVT, clean the contacts and reseat it.
              He has confirmed today that it has resolved the issue. many thanks for your responses guys.
