drivers on OSX?
  • iraklis7302
    • Jan 2022
    • 54
    drivers on OSX?
    hello dear friends
    i have iMac and my black and white prints on my KONICA MINOLTA machines still counts for color pages.on the other hand these pdf sheets counts for black and white on my PC.i know that maybe is drivers problem,because osx has Post Script drivers.can anyone suggest me anything?thank you in advance
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: drivers on OSX?
    It's the app not the OS.
    Use foxit reader to print instead of Adobe.
    Adobe thinks black is composite black.
    Adobe is aware and really does not give a hoot.
    You can also just change the print to Greyscale in the driver so it uses only black but that won't help mixed jobs.
    • iraklis7302
      • Jan 2022
      • 54
      Re: drivers on OSX?
      thank you for your answear but the result is the same.i print mixed color and black thats because i want to solve my problem.im still thinking thats drivers
      • Synthohol
        • 5849
        Re: drivers on OSX?
        so you are not using model specific drivers?
        find your driver here---> drivers
        you run the image, run the installer in the driver folder so it will put the drivers in your library (not used to install directly)
        then add the printer but select the correct driver from the "other" dropdown.
        btw, it it set to autocolor? there might be a way to play with the sensitivity of it i just cant recall now.
        let us know!
        • iraklis7302
          • Jan 2022
          • 54
          Re: drivers on OSX?
          let us know!
          thanks for your reply,yes its aytocolor of course,but i cant find the drivers on my library folder.i installed the drivers you sent me but where can i find them to put them on "other: option?
          • Synthohol
            • 5849
            Re: drivers on OSX?
            when you first start to load the printer, one of the screens asks for the driver, usually it starts with "generic PS driver" hit the dropdown and select "other software" and a whole list of potential drivers comes up. choose the "installed" konica driver from the list. if it didnt install it to the library try the whole process over.
            watch this video, but i would use IP protocol instead of hp jetdirect. YMMV
            https://youtu.be/lBjgKTF72Is
            dont forget to use CUPS to finalize default settings as it normally sets duplex by default. this can be annoying to users that have to click 1 sided all the time.
            Enabling CUPS Printer Interface for Mac CUPS (formerly known as Common UNIX Printing System), is a network printing system that allows Mac OS devices to connect to various printers on a network, including Cash Drawers. As the CUPS Web Interface may ...
            • iraklis7302
              • Jan 2022
              • 54
              Re: drivers on OSX?
              https://help.hikeup.com/portal/en/kb...erface-for-mac
              • Synthohol
                • 5849
                Re: drivers on OSX?
                what model specifically?
                • Synthohol
                  • 5849
                  Re: drivers on OSX?
                  in [Quality], click [Quality Adjustment
                  make sure all these are set to black/pure black.
                  it may print greys as composite black.
                  • iraklis7302
                    • Jan 2022
                    • 54
                    Re: drivers on OSX?
                    • iraklis7302
                      • Jan 2022
                      • 54
                      Re: drivers on OSX?
                      both bizhub C250i and c258
                      • iraklis7302
                        • Jan 2022
                        • 54
                        Re: drivers on OSX?
                        both bizhub C250i and 258
                        • iraklis7302
                          • Jan 2022
                          • 54
                          Re: drivers on OSX?
                          bizhub c250i and c258
                          • iraklis7302
                            • Jan 2022
                            • 54
                            Re: drivers on OSX?
                            its the same...the counter still counts color.....
                            • Synthohol
                              • 5849
                              Re: drivers on OSX?
                              on the copiers in system settings find
                              Auto Color Level
                              Adjustment
                              and tinker with that.
