drivers on OSX?
  • iraklis7302
    • Jan 2022
    • 54
    #16
    Re: drivers on OSX?
    Originally posted by Synthohol
    on the copiers in system settings find
    Auto Color Level
    Adjustment
    and tinker with that.
    still nothing...the same results...
    • Synthohol
      Certified Konica Expert
      • 5878
      #17
      Re: drivers on OSX?
      then fix the document, it must have been created with process/composite black instead of pure black.
      thats maybe why it cant escape printing in color.
      ive had 100% luck using foxit reader to print mixed pages that they click correctly.
      im sorry you are going through this, sometimes black images or text are dropped over a color one on the page so you cant see it on the monitor but its a color underlying layer and the copier sees this and switches to black overprint instead of just pure black.
      • allan
        RTFM!!
        • 5462
        #18
        Re: drivers on OSX?
        I have used CUPS and the PPD's since i first encountered unix based systems. Try installing the correct PPD using CUPS.
        Don't know about all the brands but some will only disengage the CMY if a certain amount of consecutive b/w pages are detected.
        It will not change to b/w after 5 pages but will if there is more per example. Not sure if that is the case any more.
        Whatever
        • iraklis7302
          • Jan 2022
          • 54
          #19
          Re: drivers on OSX?
          • B0265
            • Jan 2007
            • 718
            #20
            Re: drivers on OSX?
            That is correct. If the RGB values for "grey" areas in the pdf file are not equal (like R=128,G=128,B=128 etc) the printer thinks it is colour.In the PCL driver (Windows only) there is a setting "covert to greyscale" that allows you to set threshold value for RGB differences 1 to 20 to solve this.
