C360i wont boot
  • copyman
    Owner / Technician
    • Sep 2005
    • 4709
    #16
    Originally posted by Synthohol
    take yours and put in doner machine, if same symptom its the CPU.
    the PSU clicking though, it just screams cpu to me.
    Just to be clear put the bad CPU "with" the original storage. I guess the key here is as long as door is open no harm will be done. Would hate to brick another machine
    Agree CPU. Thanks
    • Jumping Jack Flash
      • Jul 2009
      • 66
      #17
      Originally posted by copyman
      Are you saying take a good one from a working machine to test? Will it damage the good one taken from donor machine? What about the storage board, do you swap and use the original? Does leaving door open not transfer the meters, etc?
      Reinstall only CPU-B from another copier, leave STRG-B. If the machine starts, it means that your machine is functional and the fault is CPU-B,
      I've done it dozens of times, the test using an SD card is easier.
      I don't understand what you don't understand?
