C300I problem background
  • Massimiliano
    • Oct 2019
    • 48
    good morning,
    I have a c300i with 110,000 copies all drums at 50%.
    when the customer prints in color the pages come out with a recycled paper type background, in black instead everything is ok. (I attach a photo)
    can anyone give me a solution?
  • Synthohol
    Certified Konica Expert
    • 5839
    wheres the photo?
    • Massimiliano
      • Oct 2019
      • 48
      sorry I forgot to attach.
      here they are, I also attach the print management list
      C300i.pdf
      • copyman
        Owner / Technician
        • Sep 2005
        • 4712
        I would look at black drum, even though only 50% drums can still fail, especially on low volume accounts. Are you using aftermarket toner?
        • Massimiliano
          • Oct 2019
          • 48
          original toner...
          in mono prints the defect does not appear
          • Gift
            • Mar 2011
            • 2459
            Looke a bit like a worn/aged drum (did you inspect the drum surface? I've seen many showing bare metal at both ends of the drum cylinder) or somebody messed with voltage-related settings. If the drum looks ok and you like to "fiddle" you can try initializing image stabilisation data and print the test page again without doing a calibration.
            • Massimiliano
              • Oct 2019
              • 48
              Good morning,
              I was at a customer's, I replaced all the idrums but it didn't solve it.
              then I also replaced the HV card, but the problem is not solved.
              Help me please....
              • occus
                • 337
                Do you replaced drums with new original drums(new chip)? i had this on a several c250i's.
                Easyway is to set adjustments in background voltages it will be better but not perfect.
                • Massimiliano
                  • Oct 2019
                  • 48
                  hello, new original drums
                  how do set adjustments in background?
                  thanks
                  • Cantechman
                    • Nov 2008
                    • 228
                    [ATTACH]n1616944[/ATTACH]
                    I had that exact issue before, tried every adjustment. Replaced the HV connectors, transfer belt, transfer roller, black drum, nothing worked until I replaced all 4 drums with new ones, it's been fine since.
                    • Synthohol
                      • 5839
                      only because you didnt mention it, have you tried a background data reset and stabilize? then all the gradations.
                      i would have tried that before replacing anything.
                      • Massimiliano
                        • Oct 2019
                        • 48
                        yes I had already tried these things
                        • and
                          • Oct 2011
                          • 96
                          Vpp-C1 Vpp-M1 Vpp-Y1 Vpp-K1 after you replace the drum?
                          You have all LD Light value at 1400... strange.
                          • Massimiliano
                            • Oct 2019
                            • 48
                            yes even changing drum, values ​remained at 14oo, even after replacing HV Board.
                            Very strange for me too​
                            • occus
                              • 337
                              thanks
                              You need a magnifying glass to check the colors of the dots.
                              Try not more then -3. But this is the dirty solution/workaround!
                              New drums was the solution in my cases, or sometime one of the DV.
