Bizhub C360i error code C-6102
  • otphas
    • Aug 2019
    • 119
    Hi Folks,
    customer from us get a error code C-6102 on C360i. Seems scanner cant find home position. We will go there on Thursday. Any advice?
  • Slammers
    • Feb 2019
    • 136
    Likely the rubber belt that drives the scanner bar, I keep a stock of the Timing Belts in my van. These machines eat them.
    When you replace it, make sure that the motor and the guide plates are lined up correctly as there was an issue with them being out of line which causes excessive wear on the belt.
    You can see if it has been rubbing as the metal chassis under the belt will be covered in flaked/powdered belt material.
    A161275660 -Timing Belt 335L
    • otphas
      • Aug 2019
      • 119
      HI,
      thanks a lot, will do that, i have a spare machine and will take a belt with me!
      • tsbservice
        Field tech
        • 8020
        100% correct.
