konica minolta c3321i legal size question
  • brent
    • Nov 2008
    • 1212
    so I know this is probably a simple question. but I set the paper in the manual bypass to legal.. I tell the machine its legal. then I put a legal document in the doc feeder
    and it still only copies letter . it cuts off what was on the legal original from the doc feeder.. am I missing a step or will this only scan letter since it is a letter only machine?
    thanks for the help although this isnt a broken machine hopefully the quesion will be answered. thanks
    brent
  • Synthohol
    Certified Konica Expert
    • 5798
    is the bypass included in the auto tray selection?
    • KMFLT3CH
      • May 2017
      • 226
      I've had this exact issue. You need to tell the machine it's a legal document, these little A4 machines are dumb. Either select the legal tray before hitting the start button or change original size to legal, I forget which one.
      • brent
        • Nov 2008
        • 1212
        ok dang it. the machine knows its legal and the bypass also does.. it just won't print a full sheet I lookd in the specs sheet it shows it only prints letter. so that may be the issue
        brent
        • brent
          • Nov 2008
          • 1212
          ok solution found. in the no original settings on the screen the tell the machine what the original was. you guys were right thank you
          brent
