Bizhub 368e Line smudge
  • TreeMan
    Rookie Tech
    • Feb 2025
    • 9
    Hello guys and gals,
    I worked on a copier today where they were having this image issue. Now, initially I thought it was the transfer belt cleaning blade, so I replaced the belt. Boss suggested I try changing the drum. What do you guys think?
    This gallery has 2 photos.
  • Woxner
    • Jul 2011
    • 838
    It's the drum for sure.
    • femaster
      • May 2011
      • 1482
      I've seen that before. Cleaning blade in the drum is sticking to the drum surface when the drum jogs backwards ever so slightly after a job (to get the waste toner to drop off the edge of the cleaning blade). When the machine does it's next job, the blade flips back into place leaving a little bit of waste toner behind that then shows up on the first page of that run.
