Bizhub 454e Monochrome device.
  • ltdiniz
    Supervisor de Campo
    • Mar 2021
    • 98
    I have a 454e Monochrome device.
    It has presented a TPM error and I am looking for a Firmware A61F0Y0-F00-G20-K2-100.
    If anyone has it and if possible shares it with me I would be grateful.
    I will attach some photos from a video I saw on YouTube of a possible solution with this Firmware.
    I would like to try it on this device.
  • Ziggy
    • Feb 2018
    • 780
    I dont see that firmware on KM online. I did find the information below. you may recover machine with the 789.tar file .
    KB0026854 "TPM Chip has been changed Initialize TPM settings" message
    Article metadata.
    7mo ago7 months ago
    This article has 2281 views.• 2281 Views This article has average rating: 5 out of 5 stars• (*)(*) (*) (*) (*)
    The MFP (bizhub 4e series) will suddenly lose it's meters and serial number
    Note: The following messages will be shown and will not clear:
    • "TPM Chip has been changed"
    • "Only black and white printing is possible."
    • "Fax is currently unavailable"
    • "Banner Print Job in Queue"
    CAUSE: Possible data corruption after powering OFF the MFP for an extended period of time.
    SOLUTION: Perform the steps below.
    1. Install the MFP Board if the board is a repaired board run the Reset Tar file 3 times on the MFPB
    2. Once the third Data initialization is complete Power Down the main power and wait 20 seconds
    3. Insert firmware stick with (latest Special firmware) and turn the MFP on
    4. When the firmware screen comes up check/correct Machine and Type, then flash firmware.
    5. After firmware has loaded, power down machine remove USB and power machine back on.
    6. Allow the MFP to perform it's recovery process if the CD390 occurs recover data.
    7. On reboot if the TPM chip has been changed message happens order a New SSD board through Warranty FOC program.
    8. Install new SSD Board and flash machine with latest special firmware
    9. Power ON machine and test all functions
    Related Products
    bizhub 284e, bizhub 224e, bizhub 364e, bizhub 454e, bizhub 554e, bizhub 654e, bizhub 754e, bizhub C224e, bizhub C284e, bizhub C364e, bizhub C454e, bizhub C554e, bizhub C654e, bizhub C754e, MFX-C2280, MFX-C2880, MFX-C3680, MFX-C4580N, MFX-C5580N, MFX-C3680N, MFX-C2880N, MFX-C2280N, MFX-3680N, MFX-4580N​
