Konica C224 copy problem
  • ferro10
    • Jun 2015
    • 117
    Hi everyone
    I have a strange problem on a Konica C224 The internal prints are perfect no quality problems.
    When I make a photocopy, the top part of the document appears very light. (Please see the attached document). I've tried cleaning all the glass and replacing the CCD, but nothing has worked. Could it be an issue with the LED exposure? Do you have any advice for me?
  • Synthohol
    Certified Konica Expert
    • 5891
    does it do the exact same through the feeder?
    • ferro10
      • Jun 2015
      • 117
      yes. Same problem of both glass and feeder
      • Synthohol
        • 5891
        shrink the copy to 50%, does the issue shrink too?
        • kingarthur
          • 1385
          remove and clean the PH unit, on these "earlier" models, quite often the copy/print was faded in one area, but on the internal prints everything was fine. I could never explain it. But taking out the PH and cleaning the glass for each colour resolved the issue. Using the cleaning wand makes no difference .
          • ferro10
            • Jun 2015
            • 117
            It seems strange to me if the prints turn out well. I'm aware of this issue, but usually, it's also visible in print. Have you ever encountered a case where the print was good, but the copy wasn't?
            • ferro10
              • Jun 2015
              • 117
              Are you referring to copy density?
              • kingarthur
                • 1385
                Yes, I had a couple of C454e that were driving me crazy, it just didn't make sense, even tried different DVs and DRs, used the wand to clean the glass, eventually took the PH out and cleaned, put it back, and everything was good after that.
                • ferro10
                  • Jun 2015
                  • 117
                  I'm going to clean the PH unit and I'll get back to you Thank you
                  • tsbservice
                    Field tech
                    • 8052
                    They are doing conversations of scanned image before actual print process. I can imagine something is lost during this process resulting in what you have been seen. Good catch 👍
                    • ferro10
                      • Jun 2015
                      • 117
                      Update: The issue was indeed the PH unit. After disassembling and cleaning the polygon mirror, everything started working again.
                      Thanks everyone, especially King Arthur, for the great suggestion
