i Series touch screen calibrate?
  • mrfuser
    • 1617
    Anyone know how to calibrate the touch screen on the i series? Nothing in accessibility, admin or service manual that I can find.
    K
  • tsbservice
    Field tech
    • 7981
    What's the problem?
    • mrfuser
      • 1617
      some areas of the screen are not that responsive. Is this like the old days we just have to replace the entire panel?
      • SAR
        • Jul 2009
        • 203
        It's weird on those. you push menu, counter, display keypad, stop, clear (the C button below the 0) 1166 and then you push the start button (the start button does not turn blue, it will look greyed out, but push it anyway). It should come up with a screen saying it is calibrating. Wait more than 30 seconds and turn off/on.
        • Woxner
          • Jul 2011
          • 841
          How to calibrate the touch screen
          How to calibrate the touch screen?
          There are two different methods to calibrate the touch screen on an MFP.
          1. Panel Calibration by manual operation:
          a. Press [Menu] -> [Counter] -> [Display Keypad].
          b. Press Stop -> Clear -> 1 -> 1 -> 6 -> 6 -> Start key, then calibration starts.
          c. After 30 seconds, turn OFF the main power switch.
          2. Panel Calibration by using USB memory:
          a. Connect the USB memory containing the MFP firmware data to the service port.
          For information on how to store the firmware data into a USB memory, refer to “J.2. USB memory”.
          b. While pressing the ‘Reset’ key, turn the main power switch ON.
          c. As the calibration screen appears, press the Start key, perform calibration and wait for a while.
          d. Confirm that the completion message. Touch [Close].
          e. Turn OFF the main power switch, and remove the USB memory.
          • mrfuser
            • 1617
            Thank you for the info! Can’t find that in the manual anywhere.
