KM paper size sensor VR1 adjustment
  • sunsetoutpost
    • Nov 2009
    • 54
    You guys are pretty smart, someone has to have figured this out. How can I set (fudge) the meshing of the VR1 gear so it registers the correct paper size? I've already had the drawer apart twice (remove lift motor, wires and lift plate) in order to get to the darn thing. Why doesn't the SM give a resistance measurement for a specific paper size so I can just take this apart once?
  • tsbservice
    Field tech
    • 8020
    Re: KM paper size sensor VR1 adjustment
    And machine model is?
    • sunsetoutpost
      • Nov 2009
      • 54
      DI850
      • sunsetoutpost
        • Nov 2009
        • 54
        Swapped VR1 with another machine, same result. Going to look deeper.
        • Flash
          • 378
          It has been a while since I have worked on a crusty old Di850 but there should be a tray size adjustment in the service mode.
            • 23009
            Most other KMs have a calibration in service mode. I don't know for sure about the DI850. =^..^=
            • Synthohol
              Certified Konica Expert
              • 5846
              n
              1 Enter th e 36 mode.
              2 [Adjust
              Press "
              ment mode menu Screen]
              Image adjustment".
              3 [Image
              Select "
              adjustment mode menu Screen]
              Tray adjustment".
              4 [Tray a
              Press th
              select t
              The scr
              1 (2) to
              to Tray
              Using a
              (the inn
              plates o
              and to 2
              Set the
              faces of
              pass tra
              280 mm
              djustment Screen]
              e or key to
              he tray to be adjusted.
              een changes from Tray 1 (1) to Tray
              Tray 2 (1) to Tray 2 (2) to Tray 3 (1)
              3 (2) to By-pass 1 to By-pass 2.
              scale, set the distance between
              er surface of) the paper side guide
              f each tray to 250 mm on Tray (1),
              80 mm (8.5x11) on Tray (2).
              distance between (the inner sur
              ) the paper side guide plates of by
              y 1 to 210 mm (A4R) and tray 2 to
              (8.5 x 11) respectively.
              5 Press t
              The sel
              adjuste
              After ad
              displaye
              he key.
              ected tray is automatically
              d.
              justment completes, a message is
              d.
              6 Press t he key
              • sunsetoutpost
                • Nov 2009
                • 54
                [QUOTE=Synthohol;2104233]
                n
                2 [Adjust
                Press "
                Image adjustment".
                3 [Image
                Select "
                Tray adjustment".
                4 [Tray a
                Press th
                select t
                The scr
                1 (2) to
                to Tray
                Using a
                (the inn
                plates o
                and to 2
                Set the
                faces of
                pass tra
                280 mm
                djustment Screen]
                e or key to
                5 Press t
                The sel
                adjuste
                After ad
                displaye
                he key.
                d.
                d.
                6 Press t he key
                Awesome, I'll give 'er a try
                • sunsetoutpost
                  • Nov 2009
                  • 54
                  All good now, don't know how I missed that in the SM. Guess that's one that I hadn't run into before. Thanks to all
