7 POLYGON MIRRORS
  • iraklis7302
    • Jan 2022
    • 54
    7 POLYGON MIRRORS
    HI there
    i have cleaned the mirrors from motor,in laser unit but the problem has been worst,could anyone please tell me what have i done wrong?
  • m_donakov
    • 213
    Re: 7 POLYGON MIRRORS
    Originally posted by iraklis7302
    HI there
    This is SEF or LEF print?
    If it is SEF there may be problem with drum unit. If you opened before to clean charge corona, there is 2 screw on each side where you can adjust distance from developer, maybe drum on that side is to far from develeoper, and toner is not transferd to drum. You have problem only with cyan? If you have problem cyan only than laser unit is fine. Laser unit will make problems on all colors.
    • iraklis7302
      • Jan 2022
      • 54
        • 23006
        you left out a few things.
        For starters:
        What kind of device is this?
        How did you clean the mirrors?
        Are there multiple polygon mirror motors in this mystery device, and did you clean them all?
        Did you clean the other mirrors in the laser unit?
        Did you remove any of the mirrors? It's very easy to unfocus your laser unit by incorrectly positioning a mirror.
        • iraklis7302
          • Jan 2022
          • 54
          For starters:
          ok it’s C454e,I opened the laser unit and I cleaned only polygon mirrors on motor.all mirrors in laser unit were cleaned ,nowhere dust etc.I didn’t remove anything on this unit.I cleaned with dry cloth with a little alcohol
          • tsbservice
            Field tech
            • 8004
            Now listen if you want more help. Go in service mode and print CMYK halftone patterns at density 255 and 30 A4 LEF
            Also print bird page and consumables list and upload those 10 pages somewhere in PDF format.
            • iraklis7302
              • Jan 2022
              • 54
              ok i have done this,but could you please tell me where can i find the bird page to print?
              • tsbservice
                Field tech
                • 8004
                It'sunder:
                Utility-user settings-printer settings-print reports-demo page
                • iraklis7302
                  • Jan 2022
                  • 54
                  It'sunder:
                  ok thank you ,here we are
                  • m_donakov
                    • 213
                    In my opinion, it is not laser unit problem. I will look forward in any parts that are same for each color. But first i will check the 2nd transfer roller that is on the door. Maybe toner it isnt transfered from transfer unit to paper.
                    Because you get same picture on each color, transfer unit is long and chances to get identical picture on each color are low. Check 2nd transfer roller maybe problem is there
                    • iraklis7302
                      • Jan 2022
                      • 54
                      i checked that but its good.i replaced this unit from our second c454 machine but the resault is the same
                      you mean this unit,right?
                      • m_donakov
                        • 213
                        I realy dont have nothing other on my mind. If you have another working machine swap whole laser unit from working machine you will see if there is any difference.
                        • iraklis7302
                          • Jan 2022
                          • 54
                          i need this machine and i dont want to remove something because i dont know if it continues to work well after that.
                          • tech51
                            • 846
                            Back to basics then.
                            Consumable lives? Drums,devs, transfer belt.
                            Oem or compatible toner/dev.
                            Could easily be worn drums as the magenta one is worn out at the very least.
                            Have you force stopped the machine and checked the image on the transfer belt?
                            I have seen fusers cause a similar problem.
                            • iraklis7302
                              • Jan 2022
                              • 54
                              All devs drums etc are in good condition,as transfer belt too.I used compatible timers.I stopped the machine and the image on the transfer belt is the same,I mean as in my photos,faded.the fuser is new
                              thanks for your reply
