7 POLYGON MIRRORS
  • Toxic
    • 698
    #16
    Re: 7 POLYGON MIRRORS
    Then check developing units , non OEM toners could cause this problem.
    Did you try remove transfer belt, once i found old jammed paper above transfer belt and it acts like scrapper for transfer belt.
    Edit:after look again test prints, you have almost identical problem on all colors which is suggesting it is problem with transfer belt.
    Maybe it was exposed to direct sunlight at some point?
    • Gift
      • Mar 2011
      • 2459
      #17
      I think you can expose the transfer belt to sunlight all day long^^
      I agree that this might be prob with non-oem stuff.
      • tulintron
        • Jul 2014
        • 668
        #18
        Originally posted by iraklis7302
        ok thank you ,here we are
        Well...If before repairing the laser the defect was not this, you caused problems with the laser yes.
        We have 04 colors, 01 engine and 07 mirrors. Discard the top mirrors as they are for each color.
        Some of the 03 remaining mirrors have some tiny mark, causing the same failure in all colors, or incorrect positioning.
        NEVER repeat this feat. You may have lost the laser.
        I repeat. Just check this if before opening, the defect was not this.
        • iraklis7302
          • Jan 2022
          • 54
          #19
          AT FIRST my machine printed well only one side....if i printed 2-sided pages or more,then the problem was faded colors as in my photos.Then i opened and cleaned the mirrors and the problem moved to all pages.not only the first.i will open the laser unit again to see more clearly
          • iraklis7302
            • Jan 2022
            • 54
            #20
            here is the answear,its not the belt
              • 23010
              #21
              You're losing second transfer ... don't know why. =^..^=
              • iraklis7302
                • Jan 2022
                • 54
                #22
                ok I have just found the problem.there was HV board.now my printings are great.thank you all for your help
                • tsbservice
                  Field tech
                  • 8053
                  #23
                  Some pictures will be great asset to your findings.
                  • iraklis7302
                    • Jan 2022
                    • 54
                    #24
                    ok here it is
                    • tulintron
                      • Jul 2014
                      • 668
                      #25
                      What's scary is how the laser would damage the HV board...
                      Congrats.
                      • iraklis7302
                        • Jan 2022
                        • 54
                        #26
                        Congrats.
                        yes i dont know why this is happen...im trying to find the problem to my HV board now.i am measuring the voltage regulators,capacitors etc,thanks for your reply
                        • copyman
                          Owner / Technician
                          • Sep 2005
                          • 4765
                          #27
                          I have a few hundred "4" series I service and don't think I've ever had to clean the laser unit. I have some in dirty places and never had to open the laser unit.
                          Even though this whole thing don't make sense and will never really know what the real issue was machine is fixed and all that matters.
                          • iraklis7302
                            • Jan 2022
                            • 54
                            #28
                            • Albonline
                              • Sep 2008
                              • 1153
                              #29
                              this really looks like a transfer roller issue. what does the image on the belt look like.
                              • iraklis7302
                                • Jan 2022
                                • 54
                                #30
                                hi there and thank you for your reply,i found the problem as i wrote before,there was th HV board
