Biz Hub c3850 waste tank message
  • copierlady
    • 338
    Hey guys,
    I have a Biz Hub c3850 with waste tank message. Customer has several machines and no new tank. I have tried to empty the tank, switch the tank from another machine with no results. Do the new tanks have chips on them like the toners ? Why will this machine not clear the code?
    TIA
  • dave w
    • Jun 2015
    • 230
    Re: Biz Hub c3850 waste tank message
    Not worked on this model but you may find the waste toner full sensor could be dirty, constant full message.
    • Albonline
      • Sep 2008
      • 1144
      there is a clear plastic window, protruding from the center bottom edge that needs to be cleaned after you empty the box. some need to be drilled and cleaned through the hole. tape the hole when done.
      • tsbservice
        Field tech
        • 7985
        Still not explaining why WTB from working machine didn't clear the message.
        OP what was exactly message?
        • Synthohol
          Certified Konica Expert
          • 5806
          If you tape the hole it blocks the light just as toner did.
          • Albonline
            • Sep 2008
            • 1144
            depends on where you drill it . the ps looks through the plastic part horizontally
            • Albonline
              • Sep 2008
              • 1144
              Originally posted by copierlady
              Hey guys,
              TIA
              i have seen more than one of the box full sensors knocked off, or just broken.
