C300İ alternatives
  • Ghostlover34
    • Oct 2024
    • 20
    C300İ alternatives
    Hello brothers, currently we have the 300i series in stock but since it is no longer produced, the 301i series has arrived. Instead of changing my current configuration, which series should I switch to continue working with the same system for parts and toner?
    - What is the difference between the 300i and 301i series?
  • copytechtrouble
    • Nov 2020
    • 106
    I'm open to correction but they have different fusers but the rest of the parts are compatible, drums, belts and toners.
    • Digital
      • Feb 2021
      • 18
      Yes, only the fusing unit change. Another difference is the bypass: they changed it in 1i series, now it's like the C308.
      • occus
        • 337
        And the df-632 (V2) is not the same
        • kingarthur
          • 1355
          it takes a different CPU board and base board are different, even though the FW is the same
