Error code 33-01 on 758
  • Ado Mmoloki Moepedi
    • Jan 2022
    • 32
    [Error Code] Error code 33-01 on 758
    I have a Konica Minolta Bizhub 758, I copied a 10 original page for 100 copies document in the morning without any problems, now I am trying to do another 100 copies and some papers seem to be a bit crumbled when exiting the finisher some get crumbled up enough to cause a jam and produce the error code 33-01. What might be the cause of this. The error code is 33-01.
  • Gift
    • Mar 2011
    • 2459
    Re: Error code 33-01 on 758
    What do you mean with crumbled? Does it looks like ironed with creases?
      • Jan 2022
      • 32
      Yes in middle of the paper for those that make it out of the finisher but the one that cause jams are folded up a bit either before or after the Fusing unit.
      • Gift
        • Mar 2011
        • 2459
        OK - I'd probably start checking the fuser and testing a fresh realm of good quality paper against the currently used paper.
          • Jan 2022
          • 32
          The heat roller looks to have taken some beating from what I can see. Tried to upload a short clip but that failed. I think the problem maybe with the fuser as I have tried with fresh paper of better quality.
          • tsbservice
            Field tech
            • 8039
            Are you sure for jam code? Don't have manual handy but can't recall such code on other bizhubs.
              • Jan 2022
              • 32
              Yes, I also got 33-02 and 33-03 but i think that because of the messed up paper getting jammed up in other places.
              • Synthohol
                Certified Konica Expert
                • 5877
                Take off the cover on the right side of the duplex.
                There is an upper motor that the belt slips off.
                I'm sure I have a pic on this site but take off the cover and watch the belt and see if it is slipping off to the left.
                • tsbservice
                  Field tech
                  • 8039
                  Can you post scan of Error code list and Consumables life list?
                  • Synthohol
                    • 5877
                    See post #2 from me here....https://www.copytechnet.com/forums/k...ml#post1768491
