I-series firmware won't load on new storage board
  • mascan42
    • Oct 2008
    • 485
    I've had probably 6 or 7 machines that have an issue after replacing the storage board where the MFP firmware won't load. It usually fails at 70%. Partitioning the drive doesn't help. Service mode won't open. The only solution seems to be to run the reset tool, which loses all settings and meters.
    Does anyone know why this happens? Is there anything that I can do when changing the storage board to prevent it?
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: I-series firmware won't load on new storage board
    you wont lose anything if it can get to svc mode. stop 9 or stop 0 C there is engine data backup.
    backup first so the reset procedure should come up "restore data" after the 3rd reboot.
    • tsbservice
      Field tech
      • 8020
      How exactly you did partitioning the drive?
      • rrrohan
        • Sep 2011
        • 1977
        yeah i was kinda annoyed when i recently ordered a new storage board KM send me the old style.
        My problem was it would lock up after a print job and enter CE mode would lock up the second you entered code then attemtped to login
        for me my fix was base board/MFPB
        • kingarthur
          • 1369
          Which I-series model are we talking, on the C3350i when replacing the SSD, i was told to install the "boot FW" which, if i remember was either FW version G00-3B or 7B, then load the latest FW
          • Gift
            • Mar 2011
            • 2459
            you can also try flashing an ancient FW version
