Error Code C6751
  • Ado Mmoloki Moepedi
    • Jan 2022
    • 32
    [Electrical] Error Code C6751
    I have a Konica Minolta Bzhub 758, it was working fine until a power cut occurred whilst it was still in operation. Now it is displaying the Error code c-6751. Anyone ever had this issue?
  • copier tech
    • 8174
    Re: Error Code C6751
    • Code: C6751
    • Description:Causes:Remedy:1. Correct the harness connection between CCDB PJ3-MFPB CN9 if faulty. 2. Correct the harness connection between CCDB PJ5-SCDB CN5 if faulty. 3. Correct the harness connection between SCDB CN1-DCPU CN005 if faulty. 4. Check for possible extraneous light and correct as necessary. 5. Clean the lens, mirrors, CCD surface, and shading sheet if dirty. 6. Correct reflective mirror of the scanner if faulty, or change scanner mirror. 7. Replace SCDB 8. Replace the CCD unit. 9. MFPB F3E conduction check 10. Replace MFPB.
      • Jan 2022
      • 32
      • Code: C6751
      Thank you for this, already went through the SM. Was hoping that maybe someone has had a similar experience to reduce the troubleshoot time and effort.
      • occus
        • 337
        Yes had this on 2-3 c258... reset and it works again... no calls since then.
          • Jan 2022
          • 32
          Tried that and it worked. Thanks bro.
          • Firmaware
            • 30
            Hello, we have the same failure on a C458. What was with 758?
            Gesendet von meinem SM-G980F mit Tapatalk
            • tsbservice
              Field tech
              • 8020
              I think he said trouble reset worked for him. Did you try it?
              • nullskull
                Learning
                • Aug 2023
                • 445
                I can confirm that clearing trouble code under admin mode works.
