C6500 Init toner density sensor. ERROR
  • L0rdC
    • Feb 2021
    • 82
    Hi all, I just changed the k developer to a c6500, I'm following the service manual procedure (as usual) but running the Toner density sensor initial auto. the ERROR message appears, does anyone know why it doesn't run?
  • orestesp
    • Sep 2019
    • 226
    Re: C6500 Init toner density sensor. ERROR
    May sound stupid, but have you closed the toner supply door and the front door as well when trying to run the TCR sensor initialization?
    (Had this happen to me before and I was left wondering for 10 minutes straight why it wouldn't do it )
    • wjurls
      • Feb 2017
      • 498
      Did you by chance vacuum the developing unit without removing the tcr sensor first?
        • 23009
        Similarly, if there is a paper jam in the machine that you are not aware of, none of the setup simulations will run. You must boot up into "Normal" mode to identify and clear the jam, THEN run setup simulations. In service mode the machine cannot display the jam condition, just "ERROR". =^..^=
