KonMin Bizhub 654 will not scan to email.
  • kuby
    • Oct 2007
    • 1410
    Have a customer that has a Bizhub 654 that all of a sudden will not scan to email. Do not normally work on these just trying to help out. The only message they said it gives is "Failed to complete the job". Not much help in telling you what to look for?
    • 14894
    Re: KonMin Bizhub 654 will not scan to email.
    If you go into Admin mode - Network settings - Details you can turn on the network error code display setting. That will give you an error code that will give you more details on why the scans aren't going through.
    • Synthohol
      Certified Konica Expert
      • 5868
      It's a non-e machine. You can dork around with special firmware and dip switches and keep you fingers crossed or just dump that dinosaur and get a machine that is compliant with today's security protocols.
      Better to just upgrade them. We drop contracts on non e models because they are too old and discontinued.
      Really time to upgrade.
      If they want to go cheap, get a desktop AIO for scanning and just copy and print to the 654
      • copyman
        Owner / Technician
        • Sep 2005
        • 4738
        Agree with Syn, with it being a NON-E it's going to be a real challenge to get it to work. I know what you are going to say, "but it was scanning". All it takes is a MS update or any other minor change and really tough to get it to work. I've had this exact scenario several times over the last year or so. I recently changed a C454 with soft switches & F/W to make it an "E" version and my IT guy still couldn't get it to work.
        It's one of those hit or miss things. Hopefully you will get lucky.
        Best of luck
        • kuby
          • Oct 2007
          • 1410
          Re: KonMin Bizhub 654e will not scan to email.
          Have not seen the machine before. It is a BizHub C654e, has firmware Version 6. The error code 599 when trying to send to email address. Which relates to the SMTP server. The IT guy says that there is nothing wrong with the SMTP server ? So what do you do? Upgrade the firmware? Do not have firmware for this machine.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4738
            Well the E version makes it very possible to configure. Yes I would first update the firmware to latest version
            PM me your email and will send you latest FW via a file service (too big for email).
              • 14894
              If you are using Gmail you may need to change to 2 step verification.
              • Synthohol
                • 5868
                in gmail you can generate an application password that works.
                Sign in using app passwords - Gmail Help
                • servisource
                  • Jun 2011
                  • 7
                  Common problem - windows update turns off smb 1.
                  Go to
                  control panel
                  add and remove programs
                  turn windows features on off
                  go down list and see if smb 1 is checked if not check it.
                  restart computer
                  If gmail setup go to gmail account and see if secure app it turned off.
                  Bob
                  • kuby
                    • Oct 2007
                    • 1410
                    Never updated firmware on a KM machine. Have you ever had one crash from a firmware update ? Just asking. If so what do you do to get it back going again?
                    Have not upgraded firmware yet I am getting them to reboot the server first and see if that fixes the email problem.
