C6500 custom brochure
  • Robin (ACS Collective)
    • Nov 2021
    • 22
    Hello everybody,
    is there a chance to trick the system of c6500 (Finisher: FS-612) to produce a brochure of size 110x174mm (paper=220x174)?
    Given an A5 brochure I see that the staples have enough space to staple within a space of 174mm. But the machine refuses...
    Thank you for every hint!
  • Synthohol
    Certified Konica Expert
    • 5902
    Re: C6500 custom brochure
    110mm is only 4.3 inches. The distance between rollers is wider than that so no. It's not possible
      • 23010
      You can print it SEF & duplex, but the booklet maker will not fold & staple so small a booklet. It's a software issue with the machine/accessories. =^..^=
