KM C454 getting some cyan on ky prints
  • positiveg
    • Jun 2018
    • 299
    Can you guys tell me if it's being caused by this?
    I've changed the developer unit etc to make sure what it is.
    Please let me know if it's the roller. I've tried cleaning it just in case.
    Sent from my SM-G780G using Tapatalk
    • 23010
    Re: KM C454 getting some cyan on ky prints
    Are you concerned about the small amount of residual toner on the second transfer roller? Most of that results from toner density and color registration patches on the primary transfer belt transferring to the second transfer roller during calibration. It happens on every machine.
    If there is an image quality issue in your picture samples, I'll need a better sample to see it. =^..^=
    • positiveg
      • Jun 2018
      • 299
      This is the print scanned in so you can see.
      And the line runs differently based on the orientation of how we place it in the machine. Thanks.bad print.jpg
        • 23010
        I see a cyan patch in the bottom third of that scan. Is that it? Is it always cyan or other colors? =^..^=
        • tsbservice
          Field tech
          • 8040
          I would remove ITB unit and clean recycle section from debris, also when I'm there will clean 2x IDC sensors.
          • Mr. Breaker
            • Nov 2014
            • 17
            Second that, also take a look at the cyaan drum life. But first check the ITB cleaning as stated.
            • positiveg
              • Jun 2018
              • 299
              Thanks much. Sorry for taking a while together back. I'll ask the tech to take out the IBT and look. We changed the belt I think in November. And the Cyan drum is new as well as the cyan developer. Thanks much
              • kingarthur
                • 1383
                looking at the top of the page, you appear to need a K drum
