I don't see anything about a serial number range in the manual. Have you loaded the appropriate firmware for your finisher?
I am going to buy a used finisher FS-532 which I want to use on the C3070.
The FS-532 previously worked with the C1085 machine.
Will FS-532 work properly in my C3070?
We've swapped finishers from a C3070 to a PRO1100 with no issue. The only thing to make sure of is that the correct firmware is loaded to the copier. =^..^=
The latest firmware for the FS-532 connected to a C1085 should be level 90. Make sure you have the latest while still attached to the 1085. If at level 90 it should go from C1085 to a C3070 no problem. There is a newer model FS-532 that KM has been kind of quiet about.
They use a different control board and a pair of door switches instead of one. I've only seen a couple of them thus far connected to a Pro 1100.
