I’m encountering a strange issue and could use some advice.
I have two C558 units, both originally designed for 110V. They work perfectly, but here in the EU (220V) I’ve been running them through a voltage converter. The converter works, but it’s expensive, constantly draws power, generates heat, and isn’t ideal for long-term use.
To avoid the converter, I sourced all the components needed for a 230V conversion:
- A795M40B00 – Power source (230V)
- A79JM40H00 – Noise filter (230V)
- A79KM40D00 – Fixing coil (230V)
As far as I can tell, these are the only components directly connected to live mains voltage.
However, after installing them, the printer powers on but immediately shows the error:
C-3B09 – IH Communication Error.
The only “signal” connection in this chain comes from the noise filter, which has a small three-pin data connector. I followed the full troubleshooting steps from the service guide:
- Checked all connections and fuses
- Replaced all of the above components (I have spares for each)
- Verified that all parts seem to work properly
Despite this, the printer seems to expect some different signal—possibly from the noise filter—than what it’s receiving. I can’t find any other relevant components in the mains path.
I even wiped the storage partitions and reinstalled the firmware, but the problem persists. This leads me to think it could be either:
- A service mode setting telling the printer to expect a different value from the noise filter, or
- Something entirely unrelated that I’m overlooking
Does anyone have ideas on what I should check next?
