Konica Minolta C452
  • Rod
    • Mar 2022
    • 4
    [Misc] Konica Minolta C452
    Join DateMar 2022LocationRandburgPosts1Rep Power0
    Konica Minolta C452
    Greetings from Randburg, South Africa. One of our printers, a Konica Minolta C452 which we've had since the Dead Sea was still listed as critical, has developed a thin magenta line on many of the prints. I am NOT a techie, or mechanic, but I am capable of wielding a screwdriver.
    I've tried replacing the toner cartridge and cleaning the imaging unit. It persists. Cheap solutions only please Our exchange rate to the US$ is about ZAR15.62 to $1.
    Thank you.
    Konica Minolta C452
    Thank you.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4886
    Re: Konica Minolta C452
    Greetings,
    If line is only magenta color then it is time to replace the magenta imaging unit. At a certain point cleaning the drum will do nothing and image unit needs to be replaced.
    The color image units are very expensive. There are no "cheap" solutions with image units unless you can find rebuilt unit but I personally don't have much faith in the rebuilt units.
    • DelawareJim
      • Jan 2008
      • 66
      If the thin magenta line is close to the top or the bottom of your copy, turn the stack of new white paper in the paper drawer from "portrait" to "landscape". The magenta line would still be formed, it would just print off of the edge of the copy paper.
      Something else to try. Just inside trays 1 and 2 (pull open each drawer and look to the left across the top front of each tray) you will find a hidden compartment that has some tools inside. Pull out the long cleaning wand with the cotton cleaning cloth on it and clean underneath of the image unit. Looking into the copier, look just below each image unit and you will see a very small square opening just wide enough to insert the cleaning wand. Wipe each of the 4 holes (one for each color) about ten times. This may help.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4886
        The wand is to clean laser print head windows and would be more for light steaks not colored lines but Jim brought something else to mind I failed to mentioned in my original post, pulling the blue circle levers in and out on image units "could" correct lines but is a shot in the dark.
        • copier tech
          • 8300
          Konica Minolta C452
          Thank you.
          Konica Minolta C452
          Thank you.
          Sounds like you need to replace the magenta imaging unit.
          They are expensive however there are 3rd party rebuild kits available a lot cheaper.
          • Rod
            • Mar 2022
            • 4
            Thanks so much for the suggestions. I've had to bite the proverbial bullet and buy a new unit. My bank manager isn't impressed.
            • Gift
              • Mar 2011
              • 2456
              Hi Rod, you might check the status of the remaining consumables before ordering a new unit (unless you find a very good deal/price). It's not unlikely that the other color IUs are going to opt out soon in case they exceeded their lifespan and have the same count as the magenta one.
              • Rod
                • Mar 2022
                • 4
                Thanks Gift
                Proof that the light at the end of the tunnel is an oncoming train. My bank manager already hates me. Should I tell him to contact you directly? Thanks for your help though. It's appreciated.
                • Gift
                  • Mar 2011
                  • 2456
                  No way^^ - he seems worse than any cruel mother in law I can imagine
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4886
                    Thanks Gift
                    You can tell him to contact me directly if you like and will tell him he is a cheap bastard using an OLD no longer supported copier. It hit "end of life" status 2019 (see attached)
                    He should feel fortunate that the magenta image unit is all the machine needs. It is a maintenance item and usually last way beyond rated life. So anyway you look at it the bank is way ahead of the game!
                    Best advice you can give bank manager is, since the machine is no longer supported by Kon/Min a day is coming in the not to distance future where parts & supplies will be UN-available.
                    Best of luck
