Good day everyone,
As the title says, I have a pro c754 model that I'm trying to print a 70 * 20 cm paper sheet on. My problem is that every time I change the size in printer driver settings, microsoft publisher doesn't show said size and instead defaults to a preset one. I thought the problem might be from publisher itself so I exported the file to pdf.
The pdf file adjusts to the correct size when set, but the job order doesn't go through. To be exact, it starts to go through but then disappears after a second or two with no error.
The printer is set to banner printing.
I've seen on an another post setting paper type to thick 1+, so I thought that might be it. But the printer already sets bypass tray paper type to thick 1+.
I've also reinstalled the printer driver, but the problem persists.
So now I'm all out of ideas.
Any pointers are appreciated.
