Almost all of these DF-617 ADF's for the BH-C-280/360 do have a slight skew. The original is turned a few degrees on its vertical axis, its not a distortion of the image, but the leading edge is just not parallel to the machine.
The adjustment under the right hand hinge is not always sufficient to adjust. Ofcourse are copies/scans from the platen 100% correct but via the ADF there is this skew. That's why lifting the front left corner of the sanner section would not help either.
I cannot find any other skew adjustments nor is there a loop forming system to equalize an eventual skew.
Do I miss something?
Hans
Hans
