C220 - Green color is not printed ok
  • AdrianBls
    • Feb 2021
    • 6
    Hello. I have a problem with my C220 printer. I have tested cmyk colors and everything is ok. But whem I print another colors, green have a problem. Red and blue are also ok.
  • mayorg
    • Feb 2015
    • 53
    Re: C220 - Green color is not printed ok
    You have problem with ur cyan unit check the developer or clean the charger
    • Gift
      • Mar 2011
      • 2459
      Everything is guesswork without proper samples and information about the consumable status / oem or not oem.....
      Green is mixed with yellow and cyan.... are the test pages generated from service menu with 255 density?
      • AdrianBls
        • Feb 2021
        • 6
        Thanks to everyone for answers. I solved the problem . Was from a laser slot. I cleaned all laser slots and the problem disappear.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4716
          Would check Cyan & yellow developer units for dev powder loss. Especially if ANY drums are at "0" life left. It's usually the cyan developer loss due to ANY drum being over life.
          • Gift
            • Mar 2011
            • 2459
            Plus a dirty laser unit / glasses can likely cause issues visible in halftones mainly
            • Drivee
              • Nov 2020
              • 322
              Just print 30% coverage and you will see that cyan is bad.
              • AdrianBls
                • Feb 2021
                • 6
                Thank you for your answers. I solved the problem. It was dirty the laser unit.
                  • 23009
                  You'd have an easier time diagnosing which color is the issue with a lower density halftone, like this:
