Bizhub 4750i with noisy exit area
  • krm
    • Aug 2009
    • 233
    Loud grinding kind of noise from the exit area. Single sided. Goes away after removing parts and reassembling, then comes back after a while. Anyone else have this issue?
    Thanks~
  • BHM
    • Feb 2011
    • 129
    Re: Bizhub 4750i with noisy exit area
    I don't know specifics but I hear a our techs talk about oiling a gear in that exit area.
      • 23010
      On 3320i and 4050i I've seen the exit units squeak. It's mainly because there are no bushings in the frame and no lubricant. It's not so easy to get the exit unit out, but once it's out I grease the shafts and frame holes with Mobilegrease28 (heavy clay based grease). It doesn't come back. =^..^=
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        Yep, just had this same thing this week on one of these. Remove the fuser and turn the exit drive to see all the gears that are involved (you can reach the drive motor through the frame and turn it which will turn the gears) in driving the lower exit roller. Lube all those gears where they turn to drive the lower exit roller, not the teeth since that isn't what's causing the noise. I used Tri-Flow on the gears.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • BHM
          • Feb 2011
          • 129
          I think our tech use a long q-tip with grease on it to reach the gears/shafts
          • Michko
            • Sep 2010
            • 32
            manual dont tell you have to do it.
            I guess scanner needs to come of first?
            • suomi
              • Oct 2008
              • 152
              KM INFO>>The cause is related to dry shafts on Exit Idle Rollers and unlubricated contact points on Exit Roller Assy.
              • Gift
                • Mar 2011
                • 2459
                The idle roller holder contruction is a bit "delicate"and flimsy - a tech of mine managed to pop an idle roller out while pushing it too far away from the exit roller (looking for a noise source). Things changed to a "3D Puzzle" from there......
                But yeah, some lubrication shuld do the trick - grease should last longer than oil.
                • REGSIS
                  • May 2016
                  • 435
                  That would be the longer way.
                  Back cover, upper right cover (+ inner cover), fuser, paper exit unit.
                  Make sure that arm on back side of the printer goes on top of duplex flapper when you put back exit unit.
                  • mjmjross
                    • Apr 2019
                    • 11
                    Found this out the hard way!
