758 958 toner reset engine switch?
  • allan
    RTFM!!
    • 5462
    Hi guys, can anyone please help with the engine sw to reset the toner level?
    Don't have a manual with me now, going to check if its in the manual.
    Would the 758 and 958 switches be the same?
    Whatever
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: 758 958 toner reset engine switch?
    According to the manual which is for three machines (758, 808 and 958), there is no reset for toner.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • tsbservice
      Field tech
      • 8020
      Not in manual allan. I would try the C258 switches, black was 31 if I remember correctly.
      • Woxner
        • Jul 2011
        • 851
        Engine soft switch
        31 Choice of toner reset mode (Y)
        32 Choice of toner reset mode (M)
        33 Choice of toner reset mode (C)
        34 Choice of toner reset mode (K)
        Then touch Reboot the MFP from Service Mode, your toner will reset to 100%.
        works on all 8series and I series
        • allan
          RTFM!!
          • 5462
          Originally posted by Woxner
          Engine soft switch
          Thank you guys. Will give it a go today.
          We have a short on TN712, 812 and 912.
          Been taking the chips from TN512's if have been moding to TN321 and using the ICP's to make the decanted bottles reset.
          Whatever
          • allan
            RTFM!!
            • 5462
            Ok i tried it on a C658. I wanted to clear Cyan so that would be switch 33.
            Am i a t the right place going to "stop 0 clear" engine FW soft switch?
            I then highlight 33 touch end to go back to the main service screen and restart the machine.
            But nothing changed.
            Must be doing something wrong.
            Whatever
            • allan
              RTFM!!
              • 5462
              Mmm let me try the front door....
              Whatever
              • tsbservice
                Field tech
                • 8020
                That should be correct allan but I think You have to exit frome service mode to make switch work. I did it once on C258 K toner and it worked.
                • Woxner
                  • Jul 2011
                  • 851
                  Should say reboot at bottom of screen. At least it does on i series.
                  • allan
                    RTFM!!
                    • 5462
                    Tried all ways with no luck. Will try it on another machine.
                    Whatever
                    • SAR
                      • Jul 2009
                      • 203
                      I trust you guys, but I can't find anything in the 8 series manuals about the toner reset mode. It's right there in the i series manual, but in the 8 series manual Engine FW switches 31-34 are listed as not used. Is this something they added later?
                      • tsbservice
                        Field tech
                        • 8020
                        Afaik not. But good question it may work after some FW/Function version.
