Bizhub 458
  • Reed
    • Feb 2011
    • 256
    Bizhub 458
    When the customer is scanning to email or folder a random page or two will be rotated 90 or 180 degrees. I have changed out the adf (DF704). Has anyone else seen this?
    thanks
  • kingarthur
    • 1306
    Re: Bizhub 458
    does it have searchable PDF fitted to it, if so - turn off "auto rotate"
    • Reed
      • Feb 2011
      • 256
      Re: Bizhub 458
      I can't seem to locate the"auto rotate"
      I have already set the default scan size to 8 1/2x11
      • emujo2
        • Mar 2017
        • 1580
        Re: Bizhub 458
        Divide and conquer...Are you getting any of the same rotation when you make copies? Is mixed originals on? Have you got in and really cleaned the length sensor? I'm wondering if it's detecting originals longer than 8x11 and flipping them to fit the page..I think the auto rotate for scanning was removed from the scan choices many years ago when DC reader did the job just as well for free. E
        • Reed
          • Feb 2011
          • 256
          Re: Bizhub 458
          It only happens when scanning to a destination. I tried 2 DF 704's and cleaned the adf (DF 704) sensors on both document feeders that I tried. I also changed out the Dual scan PCB that attaches to the MFP PCB ( no luck) I replaced the HDD today but left the OCR dictionary off (meaning I did not install in onto the New HDD) If they have no problems after a day or so I will go back and install the OCR dictionary. I was wondering if that may have been causing an issue
