C224e image problem
  • jwai
    • May 2018
    • 504
    #16
    Re: C224e image problem
    the customer use a period they called image not good.
    i observed the C image problem, like before Y problem.
    got a cyan copy and print cyan halftone pattern they are normal.
    last time i replaced print head, it will cause of same problem or other else?
    • copier tech
      • 8127
      #17
      Originally posted by jwai
      Hello,
      One customer called print quality no good.
      I got test print the pattern is so strange, G 100% to 80% changed blue, one yellow block missed, and yellow edged.
      The machine displayed P5, P8, P21.
      I tried to replace Y drum, Y developing unit, checked transfer unit and print head unit but still same.
      Any ideas about this case?
      Are you using genuine Konica Minolta toner ?
      • jwai
        • May 2018
        • 504
        #18
        Yes, genuine toner.
        last time i replaced PH unit and solved Y problem, few months later similar issue occurred but this time is C.
