Konica Minolta C454e - slow
  • Kenny
    • Jun 2009
    • 529
  • copyman
    Owner / Technician
    • Sep 2005
    • 4721
    Re: Konica Minolta C454e - slow
    Updating firmware is always first thing to try. Not sure but think the HDD is only used for scanning & faxing? Or guess when using ADF with copying?
    Have you tried a different driver?
    Also what happens if you take their network out of the mix and connect your laptop direcdtly and send print job?
    • copier tech
      • 8174
      Yes I agree update to the LATEST firmware see if that helps.
      If this doesn't work, a slow/failing HDD can also cause this issue.
      • Rewind!
        Somehow it works....
        • Jan 2019
        • 89
        If firmware, uninstalling/reinstalling machine on system (create new port when reinstalling), do not solve your problem ping the machines IP address. If its on a local network you should see relatively low ping results. If you see big delays, you more than likely have a routing/hardware issue on the network. I once had port 10 on a unify switch give me grief for 3 days, the whole time their third party IT kept fighting with me that it was the copier. I was given access to the server cabinet by the customer, changed ports on the switch, issue resolved, lol.
        JC
        • rrrohan
          • Sep 2011
          • 1977
          document delete after 1 day is a option you set when you create the userbox.
          ive had customers who spend 1.5 hours sending jobs to userbox then like 3 days later complained they were all missing and that was because they created the userbox without changing the delete time to NEVER
