How do we upload photos to the site?
  • Scarekrow
    • Feb 2012
    • 83
    Im trying to upload a photo by clicking attach, browsing to the file, them upload, then get error, tried 3 times. any help would be appreciated.
    Thanks.
  • Synthohol
    Certified Konica Expert
    • 5875
    Re: How do we upload photos to the site?
    Pic is prolly too big to attach.
    Try just copy and paste the image to the post.
    Sometimes that works otherwise you can try to zip it or open in paint and change the size.
    • tsbservice
      Field tech
      • 8035
      When uploading click on question mark it's self explanatory. Your best bet is convert it to pdf or zip. Uploading pictures format is pain in the a.. unless you resize a lot as Synth said.
      • Scarekrow
        • Feb 2012
        • 83
        Thanks.
          • 23010
          A better solution is to lower the resolution on your phone camera. Typically the forum will take images <1MB. Most newer phone cameras produce significantly larger images. =^..^=
          • GeneOR95
            • Feb 2018
            • 161
            There is a program which I use a lot to lower the size of image files. It is called RIOT (Radical Image Optimization Tool). you can get it here
            RIOT - Radical Image Optimization Tool
            It is free and quick and drastically reduces the file size. You do lose a little picture quality but you can adjust the reduction to strike an acceptable balance.
              This way is a bit more complicated but works well.
              Reduce the image size as mentioned earlier, some may wish to remove any gps etc the file may contain.
              Go to imgbb and upload. On the next page under the image is embed codes, the bbcodes section produces a full size image or a thumbnail like below
              Copy and paste the HTML code directly into your post here.
              • Scarekrow
                • Feb 2012
                • 83
                Thanks I managed using paint program which allowed me to resize the image. Im a Boomer. lol
