Banner copy bizhub c454e
  • chawqi
    • May 2018
    • 20
    High gays !
    My machine bizhub c454e had accidently reinitialized the firmwork, but when was rebooted a message has appeared showing that there a banner print. Would anyone please tell me how to get rid of this message definitively?
  • Synthohol
    Certified Konica Expert
    • 5815
    Re: Banner copy bizhub c454e
    can you post a pic of the screen?
    just cancel the job?
    • chawqi
      • May 2018
      • 20
      thanks for your rely
      I canceled the job for many times but it is repeated everytime I switch on the copier
      • Synthohol
        • 5815
        Wow gotta find the PC that is trying to send it.
        As a test, temporary change the IP of the copier and reboot see if the issue is still there.
        • chawqi
          • May 2018
          • 20
          sorry It is still there
          • Synthohol
            • 5815
            Like a banner job in the queue?
            Or just says like ready for banner or something?
            Somebody may have programmed the bypass tray for banner size by default so it looks for a banner job next.
            You can revert it to defaults. User setting copier setting factory defaults.
            • chawqi
              • May 2018
              • 20
              Doesn't work. thanks for your help
              • tsbservice
                Field tech
                • 8006
                Your battery may be dead or firmware corupted either nothing related to banner job.
                • chawqi
                  • May 2018
                  • 20
                  certainly the firmware may be corrupted, because the copier is no longer recognized as bizhub.
                  Could anyone please send me the firmware.
                  • emujo2
                    • Mar 2017
                    • 1579
                    Originally posted by chawqi
                    High gays !
                    How do you "accidently" re init the firmware (or firmwork..lol, those of you that have been around a while remember Frimware)..If it's not a dead battery, then it's a soft switch setting that got set back to factory..Any chance you see planets on the control panel when you restart the device? E
                    • chawqi
                      • May 2018
                      • 20
                      I have deeply pressed the button of the control panel
