Re: Banner copy bizhub c454e
I have deeply pressed the button of the control panel
How do you "accidently" re init the firmware (or firmwork..lol, those of you that have been around a while remember Frimware)..If it's not a dead battery, then it's a soft switch setting that got set back to factory..Any chance you see planets on the control panel when you restart the device? ELeave a comment:
Your battery may be dead or firmware corupted either nothing related to banner job.Leave a comment:
Doesn't work. thanks for your helpLeave a comment:
Like a banner job in the queue?
Or just says like ready for banner or something?
Somebody may have programmed the bypass tray for banner size by default so it looks for a banner job next.
You can revert it to defaults. User setting copier setting factory defaults.Leave a comment:
Wow gotta find the PC that is trying to send it.
As a test, temporary change the IP of the copier and reboot see if the issue is still there.Leave a comment:
can you post a pic of the screen?
just cancel the job?Leave a comment:
High gays !
My machine bizhub c454e had accidently reinitialized the firmwork, but when was rebooted a message has appeared showing that there a banner print. Would anyone please tell me how to get rid of this message definitively?
