Install firmware does not work | C3351
  • hobbele
    • Nov 2019
    • 38
    [Misc] Install firmware does not work | C3351
    Hello, everyone,
    I have problems with a bizhub C3351... I can no longer install the firmware.
    The machine was flattened with Clear All Data and the Reset Tool because it kept producing strange data before and blocked the print queue.
    If I now try to flash the firmware, the MFP board runs at 100%, scanner/printer stops at 10% and then displays NG.
    But I can start up the machine and print normally...
    What confuses me is that everything still works - as far as I've tested - when I boot up the machine...
  • tsbservice
    Field tech
    • 8020
    Re: Install firmware does not work | C3351
    Check printer and scanner serial numbers and also machine type. As per another experienced member here(Synthohol). Try to do only troubled part of firmware.
    • hobbele
      • Nov 2019
      • 38
      Thank you, I'll check that out tomorrow. The machine type should match.
      It's a C3351 and the type is A 2
      So you mean I should only activate printer/scanner? Disable MFP?
      • tsbservice
        Field tech
        • 8020
        Yes try to do only printer/scanner firmware.
        • Synthohol
          Certified Konica Expert
          • 5847
          on the old 223 series the scanner FW used to fail all the time. they released scanner only FW later but yes, try just scanner and turn off everything else.
          also make sure the scanner serial# is listed, that the machine and type are correct as well.
          • Gift
            • Mar 2011
            • 2459
            Won't hurt to prepare another stick from scratch and/or cross-check yours with another C3x51.
            • hobbele
              • Nov 2019
              • 38
              Hello and thank you for your many tips.
              Unfortunately I still have the same problem.
              • The serial number was entered but wrong, I have now corrected it
              • Firmware update without MFP board.
              • Machine Type is corecct - A 2
              • I also tried different USB sticks. also different old firmwares
              Does anyone else have an idea?
              • Gift
                • Mar 2011
                • 2459
                Nothing besides heavy "trial and error" - like flashing/downgrading a really ancient firmware or reset the machine via SP / memory clear.
                I'd probably just leave it (if it works)
                • mojorolla
                  The Wolf
                  • 2627
                  Prep your jump drives using this procedure:
                  KM USB Formatting.pdfKM USB Formatting.pdf
                  • hobbele
                    • Nov 2019
                    • 38
                    Hey thanks
                    my jump drives couldn't be formatted, so I did everything it said. It worked, but the firmware just won't install...
                    If no one has any more tips, I'll just leave it as it is and configure and test the machine as far as it goes. Hope everything works then.
