C360i with error C-2204
  • Tiagocang
    • Feb 2022
    • 62
    Got a client with this error on a 5k count C360i any1 something about this i changed waste toner box already cleaned the sub, belt always display the error
  • femaster
    • May 2011
    • 1478
    Re: C360i with error C-2204
    Any loud noises associated with the code? Maybe check the bulletin in this thread:
    I-Series Clogged Transfer Belt Cleaning Unit Bulletin.
    • Tiagocang
      • Feb 2022
      • 62
      no noises nothing just pop up the error
      i just cut some spring for prevent that happens its not that problem when machines go to clients
      ill try this tomorrow:
      • KMFLT3CH
        • May 2017
        • 226
        seen this on a few newish I-series machines and this specific post was the fix for me. direct link below:
        i series toner backup (copytechnet.com)
        "That code is related to the arm on the bottom left where the box goes not returning fast enough. Extra turn on its return spring cures that."
        • tsbservice
          Field tech
          • 7970
          [ATTACH=CONFIG]53783[/ATTACH]
          That should cure it.
          • Woxner
            • Jul 2011
            • 838
            Take the sensor out from the waste box area on the left and bend the spring. Its too weak. Cures it everytime. There is a bulletin on this. I just did this the other day. You may notice the lever is slow .
            • femaster
              • May 2011
              • 1478
              Forgot about that arm. That should get you back up and running. We did have one machine with this issue about a month ago that had slipped my mind. Spring had completely popped off the arm and was giving that error. I'm sure with the number of I-series we have out there that there will be more.
              • Osrs Tec
                • Apr 2025
                • 1
                How and What direction did You bent it?
