IU712CMY rebuild
  • sostek
    • May 2010
    • 80
    IU712CMY rebuild
    Has anyone been able to source drums,blades and PCR to repair these since they are in short supply? Lines on PCR from a failing blade.
  • byronf
    Senior Member
    • Sep 2017
    • 109
    Re: IU712CMY rebuild
    Hi,,
    I use DR313K to rebuild this unit.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4738
      Looks like Copylite products sells the correct drums, developers, etc for IU rebuild. It uses the C451 drum, same as the C654 series, etc. Not sure about the cleaning blade, this may be harder to get. I would think there are China aftermarket blades sold somewhere.
      If you can't get blade I would try rebuilding IU with new drum, grid and just clean the blade. Maybe developer? This should get you by until new units available
