C224 Black and white only
  • Tiagocang
    • Feb 2022
    • 62
    is it possible to put 1 c224 work only with B/W? i wanna change a BH 224 for a C224 but i wanna only costumers use only B/W without creating accounts
  • JasonSBE
    • Apr 2014
    • 186
    Re: C224 Black and white only
    Not sure if this would be good enough for what you're wanting to do, but if you turn on user authentication with public user you can restrict the public account to black and white for printing and copying and have the machine automatically logged in as public so there wouldn't be any need to put in any codes or anything, color would just be disabled.
    • Synthohol
      Certified Konica Expert
      • 5847
      You can lock the public acct as black only and set public as the default.
      LOL Jason responded faster
      • marvin_PL
        • Jun 2012
        • 24
        Leave the driver from 224 so user won't print on color. Next set b&w copy as default,then in bit sw hide option of copy color selecting.
        • copier tech
          • 8172
          To prevent colour printing simply install the 224 driver (not C224)
          To prevent colour copying you can hide the colour option with SW 71 HEX 02
          • emujo2
            • Mar 2017
            • 1579
            There is a C224 no color driver..This is the one I would use, not the 224. You may want to search this site for a topic about how the color option was removed from the panel accidently..Some reverse engineering may help find a way..Might even negate the need for a special driver. E
            • Tiagocang
              • Feb 2022
              • 62
              Hey, With all the tips it work great
              SW 71 HEX 02 and user auth with public without log in set and restrict colors works perfect
              thanks!!
