c3350i service mode password reset
  • adecanmin
    • Oct 2010
    • 316
    Gentleman
    Recently purchased this model and it no longer has the default password. I looked at the solutions and it refers to firmware to reset the password. I don't have
    KBA01400152 to see which firmware I need.
  • techsxge
    • Jan 2022
    • 660
    Re: c3350i service mode password reset
    Originally posted by adecanmin
    Gentleman
    Are you a customer or tech? IF you are a customer, please ask the company you bought the machine from.
    • adecanmin
      • Oct 2010
      • 316
      I hit the cancel button and it brought up this 40 digit code. I imputed the code but it said it cannot confirm. The machine is not hooked up to the network as of yet. Am I on the right path?
      • adecanmin
        • Oct 2010
        • 316
        Tech of course. I've been working on Konica Minoltas for a long while and Minoltas before that. Wholesalers wouldn't have that information. Of all the machines I've purchased this is first one that someone changed the default.
        • techsxge
          • Jan 2022
          • 660
          While i dont know about the C3350i im quite sure that there should be others Ways. The normal procedure and password 4x 9272 does not work? Can you access the Service mode when you enter trouble reset?
          • techsxge
            • Jan 2022
            • 660
            Oh alrigt because you said you bought a machine but i guess you bought it of the used market then?
            • techsxge
              • Jan 2022
              • 660
              Uhm you might be able to use A145FW.tar to reset the machine. Document does not list the c3350i but i am quite sure that there are no real differences between those machines. If you'd like to try this i can send you the file.
              • Albonline
                • Sep 2008
                • 1151
                789be is reset file for this unit.
                • adecanmin
                  • Oct 2010
                  • 316
                  Yes.
                  I have periodic access to the Konica site. I might just wait until then.
                  • adecanmin
                    • Oct 2010
                    • 316
                    If you have the file handy. I'll try it thanks.
                    • adecanmin
                      • Oct 2010
                      • 316
                      Great when I get on the Konica site in the near future I'll look for it.
                      • tsbservice
                        Field tech
                        • 8020
                        +1
                        • techsxge
                          • Jan 2022
                          • 660
                          ok i dont have the file 789be if you could send it to me when you get itthat'd be great
                          • Albonline
                            • Sep 2008
                            • 1151
                            I'm a KM direct employee, i will not send any file downloaded from the km site! sorry.
                            • techsxge
                              • Jan 2022
                              • 660
                              without meaning to offend you in any way, if you are a KM tech like you said and cant figure out what u need to do to reset a CE Password amd instead of asking your experts you ask on a forum, that sounds extremly sketchy to me. In addition to that why do you buy a used machine then?
                              Just realy curious about this, not trying to offend you.
