C35 boot up failure
  • Synthohol
    Certified Konica Expert
    • 5877
    #16
    Re: C35 boot up failure
    I'd replace the ram chip first.
    • strider5555
      • Jun 2008
      • 96
      #17
      We had many of these machines with this problem. Ultimately ended up having to replace the MFPB, which comes with the SSD. Printer_Error_Locking Up at Startup _ Stuck on hourglass (Technician).pdf7829.pdf
      See the attached PDF's.
      • jwai
        • May 2018
        • 516
        #18
        Originally posted by strider5555
        We had many of these machines with this problem. Ultimately ended up having to replace the MFPB, which comes with the SSD. [ATTACH]54159[/ATTACH][ATTACH]54160[/ATTACH]
        Thank you for your information.
        • rrrohan
          • Sep 2011
          • 1977
          #19
          if your about to spend the money on main board on such a old printer id just quote on replacing it with a C3350i
          Lets be honest C35 were bad and this is good reason to justify upgrade
          • jwai
            • May 2018
            • 516
            #20
            Yup, it's a nice suggestion, i will try to discuss with customer.
            On the other hand, i found one used MFPB, can I replace it with SSD that installed on defective board, no need to perform dip switch setting? ( counter data transfer )
