C35 boot up failure
  • jwai
    • May 2018
    • 508
    C35 boot up failure
    hello,
    one C35 copier when it turn on the screen stay on KM logo with orange lamp light on.
    the pre drive, movement and exposure lamp of scanner all work normally, it would not change to copy mode screen.
    i tried to disconnect hard disk and RAM but still same.
    have idea about this issue?
  • GIUBOSS
    • 1436
    Re: C35 boot up failure
    Originally posted by jwai
    hello,
    update the firmware, you can also do it via usb
    • jwai
      • May 2018
      • 508
      before I updated it with G05-6005BH.
      • allan
        RTFM!!
        • 5462
        Did it crash right after firmware update? Give it a flash any way.
        Right after changing a toner? That happened before.
        Battery good? Also had that were it not only loose its time but hangs on startup.
        Whatever
        • Albonline
          • Sep 2008
          • 1151
          hello,
          Can you wake it in second service mode?. also do the motors come on in the main unit ? is color calibration happing?
          • jwai
            • May 2018
            • 508
            I updated it long time ago, it work fine until yesterday.
            Yesterday customer turned on and found the KM logo displayed, with orange lamp lit up.
            Would it cause of MFP board defactive?
            • allan
              RTFM!!
              • 5462
              Remember another possibility. I could be that its failing white background correction. It the DF correction is all orange brown, lift the DF and have a look underneath it. The guide that keeps the paper close to the slit glass.
              Are you getting clear AC from the wall? The all solutions PDF could help.
              Could be the MFPB... But give it a firmware flash for good measure.
              Whatever
              • jwai
                • May 2018
                • 508
                Motors work, exposure lamp lit up, scanner move to and fro and calibration done.
                Like a normal machine start up, the difference is hold on KM logo and copy key light is orange not blue.
                • jwai
                  • May 2018
                  • 508
                  I lift up the DF and turned several times but the same issue result, consider to load FW once more but the machine cannot go to initial copy screen.
                  I wanna download that PDF however it has been expired.
                  • Synthohol
                    Certified Konica Expert
                    • 5840
                    Problem
                    Locked up at the Konica Minolta logo screen at power ON.
                    Solution
                    CAUSE: Failed Hard Disk Drive (HDD).
                    SOLUTION: Remove the hard drive as a test to see if the MFP boots. If so, replace the hard drive (p/n
                    A2X0 M72C 00).
                    • jwai
                      • May 2018
                      • 508
                      Originally posted by Synthohol
                      Problem
                      Solution
                      A2X0 M72C 00).
                      I tried to remove HDD and turned on, cannot fix.
                      Removed RAM and did once more, same result.
                      • techsxge
                        • Jan 2022
                        • 660
                        As far as i looked through it, there is nothing in it
                        Fabian's cloud
                        • Synthohol
                          • 5840
                          next i would try different RAM for sure
                          • rrrohan
                            • Sep 2011
                            • 1977
                            im pretty sure a C35 requires the RAM (not optional) so removing it if anything would make the problem worse. It would need swapping with known working DIMM to be of any troubleshooting use
                            • jwai
                              • May 2018
                              • 508
                              BTW, i wanna try to update firmware , in this condition ( KM logo freeze on panel )how to do it?
