i series OCR scan
  • jwai
    • May 2018
    • 508
    i series OCR scan
    Hello,
    If customer use A3 i series copier, scan document to Word file through OCR and edit content, which option(s) should be installed on?
  • kingarthur
    • 1356
    Re: i series OCR scan
    as far as I can remember LK-105 will give you searchable PDF, and LK-110 will allow you to search and encrypt PDF
    • jwai
      • May 2018
      • 508
      But user want a scanned image with editable Word file.
      • Synthohol
        Certified Konica Expert
        • 5824
        AFAIK only pdf scans or PowerPoint work.
        Check out the data sheet.
        Rebus recollect software will ocr word files.
        • jwai
          • May 2018
          • 508
          I checked datasheet, not sure that install LK110v2 is correct or not, wanna ask everybody about it.
          • emujo2
            • Mar 2017
            • 1579
            LK adds DOCX and XLSX, PDF searchable..So if you scan DOCX you should be able to edit the image (text only). E
            • techsxge
              • Jan 2022
              • 660
              You could just use the LK-105 and create searchable PDFs, then on the Scan folder have PDF24 convert the PDFs to word (doc, docx) if needed. I do wonder why what you have to scan and then edit with word? Usually a Programm like Adobe Acrobat Reader should work just fine? You can edit PDFs there.
              • jwai
                • May 2018
                • 508
                This is request of customer, they need to edit texts with Word format.
                They are using other brand's machines, OCR scan to computer with Word file and edit.
                • jwai
                  • May 2018
                  • 508
                  I check the datasheet, there are:
                  LK105v4 OCR text recognition : searchable PDF and PPTX
                  LK110v2 document converter pack : generates various file formats DOCX XLSX
                  It means install these two items?
                  • emujo2
                    • Mar 2017
                    • 1579
                    If this is an I series you need the LK110v3 only + the UK 211 (memory). This will give you all the features you have requested. E
                    • jwai
                      • May 2018
                      • 508
                      Thank you very much.
                      Before I consider this DOCX file only can copy and paste, not allow edit texts.
                      • emujo2
                        • Mar 2017
                        • 1579
                        Is this a question or statement???If you scan as DOCX you can open with word and edit text. If you cannot open it you are probably getting a TIFF, which is one of the out of the box scan formats. E
