C454e printouts are wavy.
  • Albonline
    • Sep 2008
    • 1135
    Re: C454e printouts are wavy.
    Originally posted by Barry97
    Is there any possibility if the frame is bent?
    is the feed loop sensor damaged?
    • Barry97
      • Jun 2022
      • 23
      Ran the sensor check. Looking at the Paper exit in service mode. The fusing loops value remains at 0.
      Can the cause the paper to be wrinkled/wavy?
      • Albonline
        • Sep 2008
        • 1135
        yes registration clutch stays on until loop sensor is made. this issue is more prevalent in the 654/754 series but this unit shares same basic operation.
        • Barry97
          • Jun 2022
          • 23
          #19
          So there must be a synchronization issue with two units?
          • Albonline
            • Sep 2008
            • 1135
            #20
            yes that is one of the functions of the loop sensor
            • Albonline
              • Sep 2008
              • 1135
              #21
              • Barry97
                • Jun 2022
                • 23
                #22
                I did replace the whole unit. Does the same thing. If the wiring was the problem I would see trouble codes. If there were issues with the electronic boards, the machine would also give me errors too. So would it be a possibility that the frame is bent? or the Door is the problem?
                • Albonline
                  • Sep 2008
                  • 1135
                  #23
                  yes frame damage is a possible cause, ,so is door alignment.
                  • bizhubber
                    • Nov 2016
                    • 13
                    #24
                    Not sure if this would cause your wavy copies and you mentioned replacing exit section which would rule this out, however is it possible the box had a finisher in a previous life and the sensor unit attached the exit section for the relay unit was left behind when a finisher was removed. it installs so cleanly that it would look as if it has always been there.
                    • Barry97
                      • Jun 2022
                      • 23
                      #25
                      Ok, Ill test it with the bridge and a finisher with it.
                      • Kenny
                        • Jun 2009
                        • 515
                        #26
                        did you manage to sort this? would be interesting to know
                        • Barry97
                          • Jun 2022
                          • 23
                          #27
                          Lol, doing some start up on other machines at the moment. Will work on this machine later. Still does the wavy print out. I'll swap the door when I have a chance. Let you know the outcome.
