konica minolta bizhub c3350i blue and pink lines on setup
  • brantekcc
    • Jan 2022
    • 45
    good day
    we have a bizhub c3350i that is giving blue and pink lines on the pages when copying or scaaning , we redone the setup procedure and after running setup again it give CD262 error code and does self diagnostics and says no error found , any suggestions please woul be highly appreciated
  • Albonline
    • Sep 2008
    • 1151
    Re: konica minolta bizhub c3350i blue and pink lines on setup
    Originally posted by brantekcc
    good day
    • brantekcc
      • Jan 2022
      • 45
      thank you , there is no 2nd network card installed in the machine ?
      can the setup be run again from start or how do we resolve this please
      • Albonline
        • Sep 2008
        • 1151
        service mode, turn off 2nd network card. Yes you can redo setup. .follow the steps in the directions exactly from start to finish.
        • brantekcc
          • Jan 2022
          • 45
          all sorted thank you for the help
            • 23009
            I came across this one myself. =^..^=
