bizhub C3350i jam 11-01
  • brantekcc
    • Jan 2022
    • 45
    [Error Code] bizhub C3350i jam 11-01
    Good day all
    we have bizhub C3350 new machine that is giving us jam code 11-01 intermittend fault , it is a new machine and is giving this issue , any solutions would be highly appreciated
  • Tiagocang
    • Feb 2022
    • 62
    Re: bizhub C3350i jam 11-01
    Countermeasure for J-1101 occurrence.pdf
    never tested this but should work
    • brantekcc
      • Jan 2022
      • 45
      Originally posted by Tiagocang
      [ATTACH]54397[/ATTACH]
      thank you i will take a look i am going to the client on monday morning
      • cyta123
        • Aug 2015
        • 46
        Recently I replaced clutch A7AHM20501
        • femaster
          • May 2011
          • 1514
          There is a newer "fix" for this that had a bulletin released in the US last month. It will probably be quite some time before the parts are available however. I placed an order for the updated parts the day after the bulletin was released, and they are still listed as NO ETA AVAILABLE.
          Bulletin_13035_Paper_Slip_Through.pdf
          • tsbservice
            Field tech
            • 8020
            [ATTACH]54410[/ATTACH]
            Brilliant engineering KM 0.5mm you must be proud of improvement
            As Albonline said i series = no real testing before market launch. Luckily still A3 models inherited solid base from previous generations.
            • kingarthur
              • 1369
              Every one that I have had, I've replaced the DFPV assy for the one in the mono version
              • avecosat
                • Jun 2012
                • 305
                I had to change the Conveyance / Paper feed assy in one C3300i .I tried everything and in the end I had to change the whole unit.
                • tsbservice
                  Field tech
                  • 8020
                  Silly question I know...but what is part number for this "DFPV assy"?
                  • brantekcc
                    • Jan 2022
                    • 45
                    the jam occurs just after the registration rolleres and fingers about 20mm past , so its not trail edge related as trail edge is still in the tray
                    • brantekcc
                      • Jan 2022
                      • 45
                      the machine only has 720 prints/copies on ?
                      • cyta123
                        • Aug 2015
                        • 46
                        The machine was 10k. But other 2 machines were only about 1k, I replaced only stopper roller A00J563600 - jams disapeared.
                        I know, it is weird like the machines are.
                          • 14812
                          I have had this jamming issue with two different C3350i machines. The first one I replaced the conveyance unit (AAJRR71411). The second one I removed the conveyance unit and cleaned the clutches with alcohol. Both procedures solved the jamming.
                          • kingarthur
                            • 1369
                            sadly, it's not one part, you have to order 6 parts to make up the one unit - and the parts arrived anything between a couple of days, and a couple of months....
                            you need
                            Shaft ACT9626300
                            Torque Limiter A0ED563900
                            Roller A11U560000
                            Holder ACT9626101
                            Compression Coil Spring ACT9626201
                            C-Clip V218030086
                            Every machine i've fitted it to, has stopped misfeeding
                            • tsbservice
                              Field tech
                              • 8020
                              you need
                              Shaft ACT9626300
                              Roller A11U560000
                              Holder ACT9626101
                              C-Clip V218030086
                              Noted. Thank you kindly.
